mgp87zxt wrote:I cant get definitive answer on this by searching.
plans are
89 s13 with r32 front crossmember and rb20det.
some say it will hit the sway bar some dont.
can anybody WHO HAS DONE THIS EXACT SWAP confirm this for me either way.
I did the rb20det into a 90 s13 using the R32 front crossmember and my swaybar did hit the oil pan.
Quote »also will the r32 front sway bar bolt up to s13?If so would this clear the oil pan? [/quote]
The R32 sway will not bolt on. I tried this. However I did cut a few inches off each end of the R32 sway bar, heated it up, re-bent it to shape, and am using that. My makeshift sway bar is working fine so far, and should continue to do so.
