95lstegman wrote:umm stronger stopping power, so what? you can lock them, so having even more front bias just means you'll have a harder time getting rid of that bias. too much bias = longer time and distance to stop the car. fade resistance is better with R32/Z32 with the 30mm rotor vs. 28mm thick Q45, and aluminum caliper vs. steel, as well as less flex for better feel and pad/rotor life.
but all in all, Q45 is dirt cheap, and more than enough for street or light track use/relatively low power.
of course, if you managed to find one of the few R32's that has the larger, 11.6" rotors, go with that. those are SWEET. if you don't, sell them to me!
also, for brake clearanceif you have a wheel with a high disk, you can sue r32/z32if not use q45
i personally use GTR32 for all my carsmy cedric has them front and rearmy stagea has them front and rear, the larger sized drilled rotors, and stainless lines
