r32 lsd
Rbpowered
Car: 92 240sx fastback with Rb25det
I e-mailed mckinney the other day asking if the had any r33 lsd's he said they have a r32 lsd he also said that was the only one that fits. i heard the r33 fits as well. dont they have different gearing? what do your guys think? i have a 92 hatchback with a rb25det
mmatl16
Car: 240sx rb20 swap
mckiknney knows what they are talking about but i would call some other places to and verify
ceniack
Car: 1992 240sx Coupe
1993 JDM Nissan Caravan
2011 Subaru WRX STI Hatchback
2012 Subaru Impreza Hatchback
i have an R33 rear diff in my s13, just put it in. gear ration is 4.11 i believe, also, you will need new axesl or output shafts (r33 rear diff is 5 bolt star pattern) or you can have them send you the axels from the r33 with your rear diff as they are a direct fit.
(speaking from personal experience, not second hand)
about the only thing you will need is new bushings on the front of the diff, and about 5mm longer bolts to hold it up.
Carl H
5 bolt axels are the same as some j30 axels.
BoostFab
Car: S13cp, S13fb, S14z
Carl H wrote:5 bolt axels are the same as some j30 axels.
just what he said...don't bother with the output shaft.
RC240
Car: 91 240sx white coupe
apparently they dont know everything. i have r33 lsd with axles in my 240sx all i had to do is change the diff cover. swap it with the original diff.
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
You should check out jhot exports i bought my r32 sub frame for 200 USD which include 5 lug big brakes and hicas
sean8564
1993 Nissan Silvia
http://www.jhotexports.com/ JHOT Exports1530-1D Crescent CourtAugusta, GA 30909Office telephone: 706-364-6446
