r32 gauge cluster in a s13
ibzbro
Car: paintball, and cars
just as the title says
themadscientist
That's the Nismo gauge panel too.
ibzbro
how can you tell. i just love the thing it was worth every bit of time i put into it. everything works. the boost and the oil pressure and all the warning lights. everything.
Joe
the spedometer.
ibzbro
[IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG]
Here is some more. they are a little older.
themadscientist
the scales are higher, stock is 180KPH and uh the "NISMO" stenciled on the speedo face:pface
Daily double, it's a GTS-T set too, how do I know?
tick tock, tick tock, tick tock
ibzbro
the first one is not mine but i thought it was. now that i look at i harder i see it. but the ones i just posted are mine the way it sits right now in the car. the only thing different is that the lights are red and not green.
ibzbro
i don't know because it has oil pressure. and what is a gts-t was that the 4 wheel drive one?
themadscientist
GXi = CA18i GTE = RB20EGTS = RB20DEGTS-T = RB20DETGTS-4 = RB20DET and 4WDGT-R = RB26DETT and 4WD
The GXi, GTE and GTS gauge cluster had a voltmeter in the top left position, The GTS-T had a boost meter, GTS-4 and GT-R a front diff torque meter. The Nismo meters came in 260KPH versions in blue or grey and 320KPH in black or white. I have the R meter in black.
Aznboi64
ibzbro - Anyway you can write a DIY on this?
ibzbro
sure i will try and start tonight.
Aznboi64
Sweet. I know I will definitely appricate it and many others.
spec-u-later
Car: Yaris...FML
What about the rb25det? Isn't that a GTS-T as well?
themadscientist
That's an R33 though, those designations are for the R32.
Nameless EJ6
Car: What the **** do you think.
Did you use the skyline dash harness to get that cluster working properly?
It looks nice, I like how the needles light up ..
ibzbro
no you use the stock 240 harness. i will show you how to do it. i is kind of a pain.
Toad[^_^]
ibzbro wrote:no you use the stock 240 harness. i will show you how to do it. i is kind of a pain.
You wouldn't happen to have any pics of the wiring would you? I've got a guy who says he can find one for me easy.
gtrperformance
Car: FULLY BUILT 1989 USDM KPS13 W/RB20DET
Update please. The PICs arent showing up.
POOPmouth
Car: The Devils pimp ride
plz update pictures and the DIY write up ...
... love the r32 cluster - and really want to check urs out as well.
gj
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
Good job for two years ago.
gtrperformance
Kansei240sx wrote:Good job for two years ago.
The post may be old but some one has got to know how to do it or atleast have some PIC's.
