R32 GAUGE CLUSTER IN 89 S13
gtrperformance
Car: FULLY BUILT 1989 USDM KPS13 W/RB20DET
Does anyone know if the R32 cluster will fit in the S13 240sx? How can I make it fit and work? And don't tell me to check the RB or R32 forums. I have a S13 not a R32 and I'm not asking a RB question.
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
I will fit but the speedo I s mechanical on the r32 and the S13 is electrical so it will no work and the Tach is calibrated for a 6 cyl car. i would Get a JDM s-13 clusterif you have a 4 cylinder
gtrperformance
I have the RB20DET engine so I should be fine then. I have a 260kph NISMO cluster. I guessing all I have to do is wire the boost and oil pressure on the cluster. Obviosly NO ONE has done this before so I guess like with the digital climate control. I did the digital climate control swap when I had the KA in my car. Various posts said that it couldn't be done without swapping out the engine and ECU. NEWBS! I even changed the bulbs in the digital climate unti and put in blue LED's. It looks bangin'.
sean8564
1993 Nissan Silvia
your speedo will not work R32 Mechanical SpeedoS-13 Electrical Speedo
gtrperformance
DUH...That's why I'll have to run the RB transmission speed cable to the cluster. It'll work then, homie.
POOPmouth
Car: The Devils pimp ride
hey good luck with the cluster swap and yess it works---im going to swap a r32 into my rb20240sx to will to a write up----lets trade info if u want ---[email protected]
armysweitzer
Car: RB20DET S13
it works it easy, if you can trace cables you can do it. Pull it and figure it out, best way to go about it.
nukeone
Yes, and don't forget to stretch the cable so it will fit the extra length required between JDM RHD and US LHD cluster location if you don't have RHD!
gtrperformance
I ditched the R32 cluster. I don't need it. I did use the tach and I used a speed cable on the RB transmission and now my speedometer works fine. I don't know how accurate it is but I don't really care. Oh well.
