OutToWinPAHC »
https://forums.nicoclub.com/outtowinpahc-u66900.html
Sat Aug 08, 2009 6:38 am
A local shop near me did it. They are using the S13 core, but they did remove the spot welds and bring it forward about 2 inches, and then they had to make extended tension rod brackets.
So I would say no to the core, but since the front end of the R32 is longer more work is needed. They also used OEM fenders and welded them with the S13 rear fender section.
