r32 factory fit on s13?
Fenvy
Car: 2005 350Z Base 6MT
does it fit? I thought the gearing is different and it shouldn't fit, no?
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
R32 WHAT?
THERE ARE ALOT OF R32 PARTS THAT FIT ON THE S13.MY R32 RB20DET BOLTED RIGHT IN, THE SUSPENSION IS ALMOST EXACTLY THE SAME, THE BODY PANELS AND LIGHTS MOUNT UP, THE REAR END IS SWAPPABLE, INTERIORS ARE SIMILAR, ETC.
Fenvy
<---what a dumb ***
sorry I meant the vlsd
PROJECTRB240SX
YES, THE WHOLE REAREND BOLTS INTO THE S13. IT'LL BOLT RIGHT UP AND YOU SHOULDN'T HAVE ISSUES AT ALL.
Fenvy
I did a search on vlsd in the past, I Found a thread saying that not all of them will fit.... something about the output shaft could be 4 bolt pattern or 5 bolt pattern and I should find out what my car has before making the purchase..? anyone know what I am talking about?
also, how can I tell from the housing that it's a vlsd unit and not a non-vlsd unit?
PROJECTRB240SX
JUST REPLACE THE AXLES WITH THE R32 AXLES.
180fan
Car: 89 fastback
Holy smokes! The front and rear ends bolt right up?! Were there any large gaps between the new bumper/taillights/etc and the body of the car?
PROJECTRB240SX
THE FRONT END IS ABOUT 1MM WIDER.... THE REAR BODY PANELS IS A CUT TO FIT AFFAIR BECAUSE WE DRIVE LOVELY UNIBODYS.
Fenvy
last quesstion: how do I know if it's a LSD unit and not some non-LSD unit?
PROJECTRB240SX
IT USUALLY HAS A STICKER.... MAKE SURE YOU ARE GETTING A DIFF FROM A GTS-T.
