i installed an r32 differential 4.36 now my speedometer is showing im going faster then i am how can i fix this by changing a ca18det speed senor or an rb20det. and will it be a simple swap
the speed sensor tells you how fast your going by how fast the transmission spining since the differentail gear ratio "4.36" is higher the transmission is going faster then with the stock differentail of 4.089 thats how the car reads your speed now in order to get a proper speed in the speedometer i was thinking of swaping the speed sensor from a s13 ca18det since it has a differentail of 4.36 or an skyline r32 that also has a differentail of 4.36
My R32 speedo is cable driven and the 240 is electrical you will not need the speedo the 89-91 Nissan 180sx and silvia had the same 4.36 rear end with the CA and all S13 european 200sx had the CA18 from 89-94
