gawdzilla wrote:i think carl just means return it from the rack straight back to the resovoir (i.e. no cooler at all)
Hey gawdzilla, are there pros/cons to installing the cooler between the pump and rack instead?
gawdzilla wrote:Darius - I don't know if it's safe to use regular stainless hose. Haven't had personal experience with stainless hose failing, but i think regular stainless hose has a much lower burst pressure rating. If you're trying to save a bit vs. the overpriced Earl's line, try gonig to a hydraulic shop and getting some of their stuff.
Everything I've ever read about stainless lines & AN fittings says you need the ultra high pressure hydraulic lines and fittings for steering or brake use. Also read somewhere the PS system can build up to something ungodly like 3000psi on full lock?
