R32 cluster in an S13
blackbeltclub99
Car: 93 RX7
how much work is involved in using this cluster? Is it a direct fit? do you need the sub harness or is it plug and play? thanks in advance.
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
what motor are you using
blackbeltclub99
Car: 93 RX7
RB20DET
Ender_Zero
Car: '03 Base Z, '91 S13 Coupe
my roomate and i tried to see if the r33 gauge pod would fit in his 92 with rb25 and it wasnt anywhere near a direct bolt-in and plugnplay. we ended up just taking the tach out of the r33 cluster and putting it in the oem cluster.
sean8564
1993 Nissan Silvia
It sould work if it a rb20 cause i have a 25 and wanted to put a 32 gauge cluster and it would not work because the speedos are diffrent and a couple of other things just take your time and it should work
