R32 brake conversion
stacy
Car: 1990 nissian 240sx se
Hey guys, I appologize if this may be in the wrong forum but I need to find out if I have a set of 4 R32 30mm calipers 4 piston in the front and 2 piston in the rear can I get the z32 rotors and brake lines to work no problems??
Hijacker
Car: '92 240sx Convertible
'94 F-150
The Z's and the skylines shared the same brakes. So a 30mm caliper and rotor should mate fine. As far as I know
I can definitely vouch for the rears being identical. I have Z32 calipers and rotors matched up to an R32 e-brake assembly.
stacy
does anyone one know for sure if this is what I am looking for to fix my e-brake problem
http://cgi.ebay.com/ebaymotors...ZWDVW
Hijacker
'94 F-150
I'm not too sure about those. I've never seen them before. Can you email him and get the instructions?
Cables from a 2+2 Z32 will fit, but you'll have to do the routing through the subframe technique to make it work. Most junkyards with a Z should have them
Courtesy sells R32 cables, which reportedly fit perfectly and in the stock location. They are pricey as they're a JDM only item being sold brand new from a dealership.
stacy
thanks
stacy
AHHH someone please help me out can someone please explain in dummy terms IF im upgrading my rear brakes to the R32 calipers which are the same as the z32's how do i make my ebrake work
Hijacker
'94 F-150
http://importnut.net/300zxbrakeswap-ebrake.htm
The second link isn't really important, he does mention the rerouting technique for S13s. This tutorial covers S14s, but the installation in the first link will be identical. Except you'll be keeping your 4 lug hubs (I assume). Also, do some searching on our site. We have a lot of info covered, and there was a big thread in the convertible forum a while ago that went in depth on the rear setup.
stacy
thanks for all the help I also found some more help using the search engine and tyoing z32 brakes and it helped
