R32 4.0.8 is INSTALLED
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
just got my car back w/ the 408 gearing. feels great what tread was left on my tires is no more. Havent been above 60mph yet but going to Brooklyn for Dinner (Peter Lugers meat fest) so will rip up the LIE and BQE a little later. Installed the speedo gear from a J30 - 391 i think. 60 mph on the speedo is 57.8 on the GPS, i think. More to follow. Had to use the input flange from my stock rear the one infiniti sent me was wrong.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Sounds good James, glad to hear it worked good.....
redmanfx
Car: 92 Q45a
More info..Details, details, details.
red
Rex
Car: None
James keep us informed ont he J30 speedo gear. translating the speed isn't an issue, but I'm not thrilled with putting the extra miles on the OD so quickly .
But the 4.08 feeling is great . Sweet spots are roughly ~20, ~50 and ~85.
I tried to swap the speedo gear and it wouldn't physically fit - I've probably put 2500 "non-miles" on the car.
Tell us more...
superuber
Yes, please fill me in. I wasn't even aware of a J30 gear swap for the 4:08 set up.Thats great news. I hate it when my kid tells my wife I cracked 105!
elwesso
2007 BMW M Coupe
Well I cant wait for James to fill us in, so i'm going to fill us in for him...
He got the diff from a R32 GTR, swapped on the Q input flange.. $80 from infiniti, but they send him the wrong one so he took the one off his old diff on. Using stock Q45 halfshafts, worked fine...
He is using the infiniti J30 speedo sensor.. Went right in, as per sijoko. the 3.96 speedo sensor is the biggest that can go in the trans... Which 3.96 is close enough to 4.08 anyway... I think that plus running 245-45-17 (25.7 OD) is accounting for his speedo error..... no problems... its a really easy job too....
Theres NO excuse for a person wtih a 4.08 for the speedo to be off!
Rex
Car: None
superuber wrote:Yes, please fill me in. I wasn't even aware of a J30 gear swap for the 4:08 set up.Thats great news. I hate it when my kid tells my wife I cracked 105!
Here's the previous discussions.zerothread?id=167764andhttp://forums.ni ... ?id=167471
superuber
Thanks! Thats one more problem solved!
jamesmost
car was rippin 1/2 the throttle and quicker and faster w/o kick down. Hit a bad bump on way home got multiple rubbings one sounds like a shield other when hit a valley sounds like an impact wrench, must be drive shaft hittimg something could not see will be on lift by 8 - 830 tomorrowTBC
jamesmost
heres the deal i bent my rear sway bar and it is hitting the input shaft flange, I need a new sway bar, and new input shaft flange, real pissed
BlackBirdVQ
Car: 93 G20, 94 Q45, 00 Altima, 01 Maxima- quite a few
James,
Does your car have TCS ? I have talked with Wes bout doing the BCNR32 rear end months back but I would like to retain my TCS. Are the ABS wheel speed sensors mounted on the output flanges on the R32 diff like they are on a G50 diff w/TCS ? My car won't even spin the tires off the line when I nail it with my sticky 245 Avon M500s, it will spin them when I brake torque it thou. That rear end would be nice to have. What do you tach at 80MPH ?
jamesmost
the rear has the sensors for tcs, tach at 60 was 2,200rpm my car lights them up w/ no brake but it did so before the diff but i have a billet high stall convertor i have the AVON mtech 550 all season (hate them but bald now so new tires to be ordered tomorrow)the rear is awsome like a new car
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
jamesmost wrote:.... tach at 60 was 2,200rpm
Ouch! Prefer tachometer at 2500 for 80mph.
jamesmost
might be 2500 at 80 did not drive it long enough before i hit the bumpengine did not sound un happy
Q45tech
333 rpms per 10 mph with 3.538385 rpms per 10 mph with 4.083 assuming oem size tires with oem sidewall stiffness with 10/32" tread depth at 35 psi inflation in 4th gear on a 90-96 Q. Obviously the rpms on above will increase 2% from brand new tread to worn out 2/32" tread.
385 x 8= 3,080-3142 [depending on tread depth] rpm @ 80 mph vs 2664 rpm stock
irax
Car: VQ35DER Powered S14.3
Q45tech wrote:333 rpms per 10 mph with 3.538385 rpms per 10 mph with 4.083 assuming oem size tires with oem sidewall stiffness with 10/32" tread depth at 35 psi inflation in 4th gear on a 90-96 Q. Obviously the rpms on above will increase 2% from brand new tread to worn out 2/32" tread.
Q45tech, i swar to god your like the latest technology of AI turned into a forum bot! LOL! you have all the answers
sijoko
Car: Black 1994 Infiniti Q45 Turbo, Pearl White 2014 Maxima Sport
Q45tech wrote:385 x 8= 3,080-3142 [depending on tread depth] rpm @ 80 mph vs 2664 rpm stock
Now you know why I had posted about swapping in the new 6L80E transmission.
You would have great acceleration with excellent fuel economy. Cruising rpms would be even lower than stock.
Anyway, until then I will enjoy my 4.08 diff.
rsiwicki
Car: 95 Q45T
congrats James on getting the 4.08 installed and working. Finally after all these years and countless discussions the Q45 owners now have a much more economical solution to getting a 4.08 rearend
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
sijoko wrote:Now you know why I had posted about swapping in the new 6L80E transmission.
When you get that figured out, I will go to the R32 differential as well!
jamesmost
maxnix wrote:When you get that figured out, I will go to the R32 differential as well!
what mods have u done to ur car ??
