r32/33/34 RB26 differences
A forum for owners and fans of the legendary Nissan Skyline and Nissan GTR.
jimmyloose
Car: 350z
I've been having trouble finding a resource that breaks down the differences between the RB26 motors that came in the different skyline chassis. Anyone?
Count Zero
Car: 1990 Nissan Skyline GT-R, Federal Legal & fully registered
Simplest terms:
Only difference between R32 and R33 is the placement of a couple plugs (like, rank-angle sensor plug is at the back on the R32, up front on R33)
R34 has same plug locations as R33, but the R34 motor has a more aggressive design on the Cams and Valves, so slightly more power.
And the R34 uses a 2-wire Crank Angle Sensor, where the R32 and 33 use a 3-wire (though that's more dependant on the ECU and Chassis it's in.....I've a R34 motor in my R32, so it uses the 3-wire sensor.)
jimmyloose
Car: 350z
so, If I go through and buy the R33 motor I've come accross and buy new cams I should be alright? I won't be doing that intially, due to the fact that I should really learn to handle the power it already has, but I want to make sure there aren't any early-production issues.
On the electronics front, I have to go full standalone. It doesn't really matter what's where.
Thanks for the help!
Cjmartz2k
Car: Hunting for a '89 GTR now
R32's have some problem with a crank collar or something like that that make them turd themselves more often than the R33 and R34 varients
Count Zero
jimmyloose wrote:so, If I go through and buy the R33 motor I've come accross and buy new cams I should be alright? I won't be doing that intially, due to the fact that I should really learn to handle the power it already has, but I want to make sure there aren't any early-production issues.
In theory, yes.....what's it going to go in?
jimmyloose
Car: 350z
Count Zero wrote:In theory, yes.....what's it going to go in?
Z33.....
:D
Count Zero
Sweet...we have 2 RB26-swapped Z33's here, they rock.
Since it's going into a different chassis and powered by a standalone ECU-replacement (like a EMS or F-CON or PowerFC), then it shouldn't matter which one you get: just tune it to run smooth & you'll be cool.
jimmyloose
Car: 350z
This isn't just an RB swap, I'm going AWD....
I need a wrecked G35x btw....
greenmonster80
Car: KGC10
R32 and early R33's have a push clutch slave where the later R33 and R34 have a pull type. Only thought that pertant since you are looking to go AWD not just a motor swap.
Return to “GTR Forum / Skyline Forum”
