BrandAidDesignG35 »
https://forums.nicoclub.com/brandaiddesigng35-u84960.html
Fri Oct 23, 2009 9:05 am
OK, did you remove the negative battery terminal before starting the install? They recommend doing this to avoid failure, I'm sorry we pushed you to install yourself, but I promise, you will have a new battery, and the total $$ will be under the initial quote from Infiniti...
Good luck man, sorry to hear
