Passenger side
Driver's side
SwissCheeseHead wrote:Are you talking about takeda or stillen gen 3? I opted for the short ram intake because of the ease of install.
nice. I had the R2C intakes for my G already and figured it wouldn't take much to make it fit the M.Darthswan wrote:SwissCheeseHead wrote:Are you talking about takeda or stillen gen 3? I opted for the short ram intake because of the ease of install.
The Takeda.
Thanks! Your car is looking nice too!CPJ LB wrote:nice job! Looks really good.
It still retains the factory ram air cowl so it is still being supplied with plenty of fresh cool air. The filter is a dry filter. R2C makes air intake filters for military applications.IlyaKol wrote:How bad is the heat soak with these units? Most CAI's lose power...any of that happening here? Also, is the filter oil based?
No problem. Let us know if you do itIlyaKol wrote:Ahh nice. I might have to get this then. Thank you!
I am thinking the baffles/shrouds around the filters are an important part of that. I wonder if one would fit my Injen.SwissCheeseHead wrote:It still retains the factory ram air cowl so it is still being supplied with plenty of fresh cool air. The filter is a dry filter. R2C makes air intake filters for military applications.IlyaKol wrote:How bad is the heat soak with these units? Most CAI's lose power...any of that happening here? Also, is the filter oil based?
It won't. I asked RED_DET and he says he's not sure anyone makes a system for the V8.DoN_BLaZe34 wrote:The stealership won't try to void your warranty for adding the intakes?
I wonder if these will fit the 5.6..
Awful for not fitting and good to know about the warranty thing even though I won't have the issue since no one makes anything for the V8IlyaKol wrote:It won't. I asked RED_DET and he says he's not sure anyone makes a system for the V8.DoN_BLaZe34 wrote:The stealership won't try to void your warranty for adding the intakes?
As for warranty, Magnusson-Moss act would require the dealer to prove that your intake was the issue in any warranty claim (virtually impossible for them to do). Better Business Bureau and Infiniti Corporate would agree with the law, and dealership would be SOL![]()
I bought the intake barely used from a G37 member that was selling his car for a really good price. I couldn't pass it up. They go for around 300 new. The hose you have to replace is a breather or vent hose on the driver's side intake. The stock hose is a formed hose that isn't long enough. All you need is a 5/16 rubber house about 7 inches long so that it won't kink when you bend it.wideopn11 wrote:What hose did you have to replace? With the shrouds around the filters I think I like this option better. Do you remember the price on this intake and also where did you purchase from?
Edit: I was also looking at these pipes to keep the stock airboxes. Probably wouldn't help power at all but would look better. Made for G37 so *should fit.
So which one are you getting again?beachbum718 wrote:I'm sold.old thread.happy I found it.ordering one thursday.it retains the cold air ram flow.nuff said.way cleaner look then takeda long.
