R200
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
RagingPanda
Car: 78' 280Z
I saw another thread about this but since it's somewhat differ I didn't want to thread jack. I have a 78 280Z which has a R200. Mine isn't manual stock since I still have the automatic rear end. Is there a way to make it a vlsd or clutch type? i.e. put a kaaz 2 way in since they make one for 240sx which use a shortnose R200. I heard it could be use for the longnose R200 as well. Just need to get a replacement for the open diff. I plan to get some parts from Arizona Z Car so I want to know what I can use or my options are before I order them.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
might want to take a good look at your diff, I believe the automatic cars still got the r180
and yes if you buy a kaaz, quaiffe , nismo etc intended for an R200 it'll fit in either cars, the only issues are taht the early r200's use ring gears with 12mm bolts and pretty much all aftermarkets are intended for the newer units with the 10mm bolts, there is an ongoing debate on this, I personally ran the ring gear with the smaller botls with no issue, some wil insist you use bolt spacers to keep the ring ger from sliding
also you want to make sure any diff you buy isnt intended fore the 240sx se which came with the vsld, ti used unequal length outpput shfts, earlier models used the same shafts as early r200's
evildky
06 Nissan 350Z GT
dave at arizona z knows his stuff but he can be a prick, but then so can I
RagingPanda
Car: 78' 280Z
thanks a lot again buddy. I think I have a R180 also Will the R200 from 87.5-89 300zxt be a complete easy swap for my car?Since the car was an auto and was converted to a 5spd from 79's transmission. As in no modification require just drop and add.
evildky
06 Nissan 350Z GT
you need the "mustache bar" form an R200 equipped S30 to bolt the R200 in, you might also have to swap briceshafts, seeing as you already had a trans swap you might already have the right one, oh and the intion flange ont he diffs vary so you might need a different pinion flange to match your driveshaft
hbpignosePA
Car: 90 240sx hatch (Jackstand Queen)
78 Datsun 280Z (RIP)
89 Toyota Cressida (Sold)
86 Nissan 200SX hatch (sold)
83 Nissan 280ZX turbo (parts car)
90 Volvo 240 (sold)
80 Toyota Cressida MX32 (new daily)
i got the mustache bar for the s30 chassis if you needed one
Return to “Datsun Z Forum”
