Right now I am trying to finish my rear end set up in the car and I believe I have been given the wrong information on another Z site. It seems alot of people in other circles refer to the Q45 differential as an R230, but from what Ive glean here it is actually an R200v. My issue is that on my Q45 differential the mustache bar mounting bolts are 4 3/4 (center to center) while my aftermarket R230 mustache bar bolt provisions are spaced for 5 1/2 (center to center). This simply doesn't bolt up and I can not return the bar since it was bought used, it is no ones fault but my own for trying to save a hundred bucks. I don't know if some where in its life span the Q45 differential I own had its cover swapped or there is massive amounts of incorrect information online, either way I have a nice billet mustache bar I cant do jack with.
My question to the gurus here at NICO is this, is there a differential cover that will fit my Q45/R200v case that will allow me to use my R230 mustache bar? If so what make and model do I look for?
Thanks!
I own the car on the left.
