I have 3 diffs sitting in my garage. One is a S13 r200 with an OPEN Cusco 1.5 way clutch type, the other is a S13 open end, and the last is a good working J30 rear but it wont fit because of my custom drive shaft.
My plan is to rebuild the clutch type if I can find new clutches, and also transplant the VLSD into the open end and shim it. I need something to use for the time being.
I just cant seem to find the part number for the front side oil seals. I tried search, google, and nissanparts.org
Please let me know if you may have part numbers for the front, and side seals.
The shim parts are
38424-40F60 =0.80mm stock38424-40F67 =1.01mm38424-40F75 =1.25mm38424-40F83 =1.49mm
Most people will add 1 0.80 shim to make the VLSD lock better, or 2 to really make it lock almost like a 2 way. I plan on adding a 1.25 for a happy medium.
