evildky wrote:lets not forget if you swap the short snout viscous into your long snout housing you'd need to retain the long snout ring gear matching the pinion gear, and of course then you need the specific VLSD output shafts, of course for all the effort you could just fab a front mount and use the short snout unit with a lengthened drive shaft
yes, you have to use the longnose ring gear.the reason?I swapped my shortnose VLSD into my longnose casing, and had it all gasketed e.t.c. back up ready to go in about 30mins!
and when you get a shortnose VLSD, you buy the whole thing, including the output shafts, so its not exactly a hassle?
the ONLY downside (for some people) is that you have to run CV axles, which is the harder part.
I have it with my CA18DET.It depends more on your driving style, I have broken many diffs with only 221HP
