Postby
s13coupe90 »
https://forums.nicoclub.com/s13coupe90-u15243.htmlMon May 10, 2004 6:36 am
I did some searches on here and other places, and have had no luck. I've been trying to find a place to order Nissan Motorsports 4.6:1 Ring and Pinion Gears. I looked it up on nissanusa.com under the nismo parts, and only found an lsd upgrade. Any help would be appriciated on trying to locate a place to order. Thanks.
Postby
Nismo_Freak »
https://forums.nicoclub.com/nismo-freak-u248.htmlMon May 10, 2004 6:36 am
s13coupe90 wrote:Straight Line :ylsuper:
A 4.60 won't improve your straight line much... especially when you get more power. You'll be going into 5th at the top end when you could have hung out 4th.
Plus you'll have hell trying to get that thing to catch out of the hole on street tires.
For the money I'd look towards getting something to improve the powerband.
Postby
clearview »
https://forums.nicoclub.com/clearview-u423.htmlMon May 10, 2004 6:36 am
did you get the 4.6 gears installed.i have a 94 infiniti vlsd rear that i put the the 4.6 gears from Nismo in. the right out put shaft doe not go into the case far enough , it now leaks oil out the right side.did you have problem with your install.
