R200 Diff in S13
Seedlessone
Turns out that my VLSD on my 89 SE hatch is now open, rather than limited slip. I've got an R200 on the floor from a 93 J30. It's an ABS diff, so I know I can't use the pinion. If the pinion is good in my S13, is it possible to use just the rings from the R200? Diffs are hard to find around here and I'm trying to use what I've got. I'd rather not try to find half shafts. Let me know.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Only if they are the same ratio. If you put the wrong toothed pinion or ring gear in there bad thing will happen. Why not just take the LSD unit form the J30 and put it back in your using your pinion and ring-gear.?
Seedlessone
So you mean use the discs and whatnot from the J30 and essentially rebuild the S13 LSD then, right? Assuming there's not a problem with my current ring and pinion, that is. They use the same discs and everything, just not the ring and pinion?
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Pop the carriers out and take ring gear off of the J30 carrier and put the ring gear from your current diff onto it. Press it back into the housing you want to use, shim it, check the backlash and call it a day.
Seedlessone
Fantastic, I don't need to buy any more parts (yet). Anyone have a better diagram than this?
