Taylor_Durdan »
https://forums.nicoclub.com/taylor-durdan-u5630.html
Mon Apr 28, 2003 5:53 am
ok. i paid every attention to detail possible when i did his harness. i do the same for all my toehr harnesses also. my g/y wire is hooked properly, that i know. but for soem reason, his a/c relay isnt getting triggered properly. in fact, the wire that normally would be ground is power in one siutation, and converts to a ground and the other side whiuch is normally dead (no continuity to anything) turns to power. very odd caer, indeed. i have never had a/c p[robs with any of my swaps except for this one. im racking my brain as well. the long and the short of the S13 SR swap to make a/c work is this:
when repinning F9&F10, pay special care on hooking up the PROPER green/yellow wire. i will tripple check my ecu pinouts and make sure once againt hat i hooked the proper one up. most SR hanress have 2 g/y wires and it can be confusing at times if you delete the wrong one. im sure its something simple, but unfortnately, he had this prob before. im thinking either a bad dryer or maybe even a pressure switch is bad. the only way i got his a/c to work was to hook power up to his compressor.
my friend had a similar prob on his old school caddy.
the fix: toggle switch for a/c compressor. hahaha
ngi, ill try and see what i can come up with. i feel ya on the whole rain part.
