BusyBadger »
https://forums.nicoclub.com/busybadger-u28281.html
Fri Jun 08, 2012 6:03 am
The clutch and flywheel combo (including a new pressure plate) runs right around $1K, I got it when FRSport was having a special and I think I paid around $900. The JWT set is good too, Soup runs that setup and he seems pretty happy with it. The JWT flywheel is lighter, so you'll have to put up with a little more chatter...but on the plus side it's a little cheaper than the Exedy setup and it will rev a little quicker.
Whatever you do, once you start getting some clutch work done be sure to get the pivot ball upgraded, stock ones are known to break (look at Hitman's post in my "What's in the box thread") over time and under fairly normal conditions, upgrading to the cro-moly pivot ball is cheap insurance.
