dldjros69 wrote:Its all about the money. If you want it they can do it. What im saying is that they will make a kit specifically for your car but most likely wont try and mass market it. 5 to 7k and you can be running 225 hp.
The man speaks the truth...
You've got to keep in mind that the QR isn't built to handle boost. Nissan's engineers built it to be light...not tough. If you do go FI, odds are you'll also have to replace a lot of the stock internals too (add on another $1-2k right there). There was a guy on the b15 boards that boosted his QR pretty successfully...I think he was running 225hp at 6PSI with no tune whatsoever. With the tune I believe it got up to 240-ish, and he topped it out at 8PSI (can't remember the dyno specs from that run though...)
Like dldjros69 said, if you've got the $$$ then anything is possible.
