Darius wrote:I am new to tuning cars myself, but I just thought of something. If your CAS was giving a faulty signal of say 16,000, wouldn't that be off of the fuel/ign map or peg the far right column of the map? I couldn't see the map extending past your redline.
Isn't this how it happens, the ECU reads the signal from the CAS and MAF to determine the cells that hold the injector duration and ignition timing and fires the injectors and spark accordingly? I'm thinking that the RB with the PFC base map, like most, tends to have a little too much timing advance up top which causes huge detonation in a very small window and can catch a person off guard if they aren't paying attention.
whoa, your thinking would be right If I was running a MAF with the PFC. I have a microtech lt12s, that has a 3 BAR map sensor. There are no knock sensors for the unit itself. Only way to find out if the CAS was spiking would have been if someone was datalogging the RPM signal on the computer. However, since we had made about 7 pulls prior without a hitch there was no concern.
The crazy signal only displays on the microtech laptop itself, it does not transfer to the in car tach. It will be fine, then just spike, and be fine again, then spike. And with the smooth I6 its hard to even hear a missfire if its on one cylinder. Not to mention when the DBB is screaming, the open wastegate is roaring, and all of our ears are plugged.
The tuner is watching the A/F's, I was watching boost, other guy was checking oil pressure. Sorta tricky to watch it all. If we had datalogged and had someone watch the screen it could have been done. Like I said tho, there was no concern at the time since all was well.
Yeah I understand about the quench area. Im going to bring the head down to my local shop have them take a look at. I wouldn't try to save it on a rebuild Id just buy a new. It's only ****ed on #2 and #6 like in the pics the rest of the cylinders are pretty good. So Im thinking just have it decked, clean the hell out of the tops of the pistons and mating surface's. Get a new headgasket on, and compresson check her. If its half way decent. She goes back in.. If not well 8 months from now I might have start up...
Also Darius you are right about the metal electrodes a good deal of fine particles were shot out of my wastegate onto the ground along with a pile of sludge seemed to be a mix of oil and coolant and fuel.
