That's right now I remember, I ended up buying both sizes so I wouldn't have go back to the parts store
Some advice to you on the swap. Make sure that the shaft is completly seated before you torque it. There was enough pressure when I did mine to trigger the torque wrench, but the axle wasn't seated all the way. I actually drove the car with it loose!!
Tighten it down with a regualr driver first then back it off and use the torque wrench.
