Wulfgang »
https://forums.nicoclub.com/wulfgang-u10889.html
Fri Jul 16, 2004 12:19 pm
Hiya fellas,
Just wondering if anyone of you guys with a newer Skyline engine (any RB series engine) has an A/C compressor bracket and would be willing to take pics.
The thing is, my RB20 bracket will not hold my S14 compressor (which was still going strong at the time of my swap). Now I'd really like to use the S14 compressor to simplify the hose situation, plus, the S14 compressor is variable displacement and thus more efficient.
I *think* that the newer RB's should have had R-134a and probably had a similar Calsonic V-6 variable compressor. If someone could take pics of the bracket, I might be able to tell.
The main difference is that the RB20 compressor (as well as older S13 compressors, SR's, etc.) bolts up on a shaft so that it can be used to tighten the A/C belt. The S14 compressor mounts directly to the bracket with 4 bolts, and the idler pulley is all that can be used to tighten the belt.
So.... anybody have one of these compressor brackets?
