superbrightleds.com does have them lasst time I checked at least. I bought mine on ebay but had to replace one due to LED's dying on one, but havent had a problem since.QX4dahuneys wrote:QXXX4,
where did you get those dome lights from? Those things are bright as hell!! I've been looking for something like that. Would superbrightleds.com carry these? If so, which ones did you get? Let me know bro.
Love your truck man!! Very nice!
http://www.superbrightleds.com...B-W24QX4dahuneys wrote:Could you guide on the website of superbrightleds.com as to which ones are they? That would really help.
Thank you.
If you just want a replacement without rewiring/etc, take your map/dome lights out and measure them, then find the correct bulb size/type on the site in the number of LEDs you want. I just ordered some from there today. My festoons (domes) measured 30mm long. You should have the same since we have the same truck. I got these in 9 LEDs in whiteQX4dahuneys wrote:Could you guide on the website of superbrightleds.com as to which ones are they? That would really help.
Thank you.
Qxx why don't you just turn your headlights off and use your dome lights, wow looks like a supernova in there!Qxxx4 wrote:mines brighter.
Ordered mine today.KyooX4 wrote:If you just want a replacement without rewiring/etc, take your map/dome lights out and measure them, then find the correct bulb size/type on the site in the number of LEDs you want. I just ordered some from there today. My festoons (domes) measured 30mm long. You should have the same since we have the same truck. I got these in 9 LEDs in white
i told you to go with the 36 LED boards! I did the >10 led bulb thing and its definately not bright enough at least for meKyooX4 wrote:Just got mine today. I put one in and it didn't work, then I remembered they're polarized so I switched it around and voila! I got two, one for each dome light. They look pretty spiffy but I'll wait til dark to deliver my final verdict. I'll probably end up replacing all interior bulbs!
EDIT:Final verdict: not quite as bright as I had hoped, but I probably won't be sending them back or getting new ones.
EDIT EDIT:Do they take a little while to warm up? They're not that bright at first but seem to get a tad brighter after a min.
Modified by KyooX4 at 6:02 PM 5/30/2009
Modified by KyooX4 at 8:32 PM 5/30/2009
damn straight.Fisherdude wrote:Tiesto? you listen to techno then huh?
