Qx80 headlight HID bulb access
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
jjrho
Car: 2014 QX80
hi, 2014 qx80.... need to change the d2s to a 6000K and a wondering how to access the bulb..it's mighty tight there....i can get my hands in there for the turn signal bulb and the 'DRL' bulb, which i'm changing to LED but...
Do i need to take the fender well covers off to access it or ...take down the bumpers to get to it ?
can someone post a repair manual diagram of the access to main bulbs ?
much appreciated....
james R
2014 qx80
marctronixx
yes you will have to remove the fender to gain access to the xenon lamp.
jjrho
Car: 2014 QX80
ok... thought so... are the push in tabs resizable ? looks like the fender cover may be a two piece part ? so i can just remove the front portion of it ?
james R
marctronixx
IIRC the wheel well finisher is indeed two parts....
you may be able to just pull the flap back enough to get in there...
jjrho
Car: 2014 QX80
ok, thanks; i think it may be two pieces in there...willl get some phillips ultinion 6K d2s first..tnx
Return to “Armada Forum / QX56 Forum / QX80 Forum”
