marctronixx »
https://forums.nicoclub.com/marctronixx-u191356.html
Tue May 12, 2015 9:34 pm
EXACTLY! its under warranty, have them sort it out.
however, I will toss out some first steps--
first thing to do is pull any DTC's from the obd port (there may not be any). if the car has a problem, it will tell you at the obd port.
what is likely going on is the ECU needs to be re-programmed and/or the BCM.
