QX70s 3.0d TRUE Fuel Consumption
A forum for lovers of Infiniti's hot-rod crossover, the FX! In 2014, all FX models will be named Infiniti QX70, in line with Infiniti's new naming structure.
darobba
Car: QX70s Premium 3.0d
Hi all, apologies if this has already been discussed. If so please point me to the relevant discussion.
I'm in Australia and thinking of purchasing a second had Qx70S Premium 3.0d.
Manufacturer claims 9l/100km as being the avg consumption.
Can anyone who actually owns this vehicle provide some real fuel consumption stats?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Welcome to NICO!
Unfortunately that's a bit of a complicated question, unless you can get another Aussie to chime in.
Fuel economy in automobiles Differences in testing standards between Australia and United States.
Octane rating
Difference between RON, MON, and AKI
Because of the 8 to 12 octane number difference between RON and MON noted above, the AKI shown in Canada and the United States is 4 to 6 octane numbers lower than elsewhere in the world for the same fuel. This difference between RON and MON is known as the fuel's Sensitivity,[4] and is not typically published for those countries that use the Anti-Knock Index labelling system.
The selection of octane ratings available at the pump can vary greatly from region to region.
Australia: "regular" unleaded fuel is 91 RON, "premium" unleaded with 95 RON is widely available, and 98 RON fuel is also reasonably common. Shell used to sell 100 RON fuel (5% ethanol content) from a small number of service stations, most of which are located in major cities (stopped in August 2008). United Petroleum used to sell 100 RON unleaded fuel (10% ethanol content) at a small number of its service stations (originally only two, but then expanded to 67 outlets nationwide) (stopped in September 2014). All fuel in Australia is unleaded except for some aviation fuels. E85 unleaded fuel is also available at several United service stations across the country.
United States: in the US octane rating is displayed in AKI. In most areas, the standard grades are 87, 89-90 and 91-94 AKI. In the Rocky Mountain (high elevation) states, 85 AKI (90 RON) is the minimum octane, and 91 AKI (95 RON) is the maximum octane available in fuel. The reason for this is that in higher-elevation areas, a typical naturally aspirated engine draws in less air mass per cycle because of the reduced density of the atmosphere. This directly translates to less fuel and reduced absolute compression in the cylinder, therefore deterring knock. It is safe to fill a carbureted car that normally takes 87 AKI fuel at sea level with 85 AKI fuel in the mountains, but at sea level the fuel may cause damage to the engine. However, since virtually all cars produced since the mid-1980s have fuel injection, 85 AKI fuel is not recommended for modern automobiles and may cause damage to the engine and decreased performance. Another disadvantage to this strategy is that most turbocharged vehicles are unable to produce full power, even when using the "premium" 91 AKI fuel. In some east coast states, up to 94 AKI (98 RON) is available. As of January, 2011, over 40 states and a total of over 2500 stations offer ethanol-based E-85 fuel with 105 AKI.[46] Often, filling stations near US racing tracks will offer higher octane levels such as 100 AKI.
quintard
Car: Infiniti QX70 3.0D
8,8 liters of fuel avg for me in france
Return to “Infiniti FX35 / FX45 / FX37 / FX50 / QX70 Forum”
