Hi, I replaced a right side mirror on a 1014 QX60 and the mirror is used.
It is in mint condition and I ran it thru all the fold back and adjustments from the drivers door panel switches. i can see in the center display
that the camera is working fine.
But there is a red X in the center display that shows up on the right side where the mirror camera is projecting.
If I change the mirror am I supposed to reset or do something that will make that red X go away? Disconnect battery and reconect 10 minutes later????
It is the exact factory mirror replacement.Ideas?
