Postby
sijia10358 »
https://forums.nicoclub.com/sijia10358-u34313.htmlSat Dec 05, 2009 6:38 pm
Hey guys I have a 2005 QX56 with about 56,000 miles. Recently the service engine light came on, I was wondering if its the same as CHECK ENGINE LIGHT. Also what kind of maintenance do I need to do to get rid of the light. Is there a list of maintenance that can guide me to fix the car?
Postby
rioredstang »
https://forums.nicoclub.com/rioredstang-u121266.htmlSun Dec 06, 2009 5:54 pm
You will have to have somebody hook up a scanner and pull codes. There are some places that do it free. If you go to a parts store and get the codes don't let them sell you anything until you diagnose the problem first. Tell me the codes and we can get started.
Postby
rioredstang »
https://forums.nicoclub.com/rioredstang-u121266.htmlFri Dec 11, 2009 4:31 pm
The U1000 is a communications code. the TCS is a traction control system code. A failure on the communication line has occurred. I would clear codes and see if it resets. All of the modules talk to each other on the hi speed can line. If a module cannot communicate for some reason it will set a code. Communication codes can be very difficult to properly diagnose. If the code resets it may have some type of failure with the traction control system. I would take to a qualified shop that deals with driveability problems.
