QX56 Power back door (Hatch)
odbaxter
I have a real nightmare. This 05 QX56 was in a rear end collision and had a new hatch installed. Ever since the power hatch has not opened at all. It will open manually. I search the forums and the is nothing out there. We have installed a new hatch motor, latch and wiring harness. We have tested the pinch strips and installed a new BCM. Still nothing is working. The switches are ok and a scan with the Consult II is not revealing anything. I suspect that we are overlooking something very minor. Does anyone have any ideas?
Thanks for any help.
Q451990
I suspect you know more about the system than most of us here... not a lot of QX56 owners here... Do you have the factory service manual? If not you can download it here. http://phatg20.net/index.php?o...id=15
Good luck!
Heath
