bjorn »
https://forums.nicoclub.com/bjorn-u41642.html
Fri Jun 30, 2006 8:35 am
Here's what I did, for anybody searching in the future:
I bought 2 new bulbs on ebay, with shipping ~$85. (btw thats a $495 difference from dealer!!!) Installed both after I noticed there was a slight color difference. Left side, disconnect battery, take it out. Carefully unhook the metal clips that holds the bulbs in place. Also unhook the ground wire on top. Make sure not to touch the bulb. Pull the bulb housing/cables out. Push the bulb down a bit, and twist to release. (I used pliers for this)Right side, you have to unscrew the air filter box, and twist it out of the way to access the bulb.
