QX4 weird power short
[email protected]
Car: 2001 QX4
We have a QX4 with 259,000 miles on it. Recently, when we turn the vehicle, and take the key out of the ignition, the overhead light and all the power goes out. There is a clicking sound that comes from under the dash by the electronic modual , or what ever it is. The first time it happened, I freaked out. As I thought about it, it appears that something electrical is wrong, which seems to originate at the brake pedal switch. When I press the brake peddle, all lights and power, comes back on.
Anyone have this problem?
O yea, If someone has the electrical wire diagram for that switch, plesae post it so I can see what else is attached to that circuit.
Sometime, the gear handle won't release also, until I play with the brake peddle for a few min.
Please help. :facepalm:
BoostMyQX4
Car: 96 Infiniti QX4
Here i dont know if this will help you out.......Infiniti QX4 1997-2003 Wiring
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
See this PDF for a comprehensive wiring diagram.
Save a copy of the entire factory service manual too if you haven't yet. To save a copy of the FSM, right click -> Save As on every PDF, save them into a single folder, then use fwd.pdf to navigate.
I can't think of anything that would cause such a strange issue like the one you're experiencing, so I don't have any suggestions, sorry.
Welcome to NICO.
