QX4-Transmission Thud between 1st-2nd
jamescflowe
Car: 2003 Infiniti QX4 4x4 LSD
White/ Silver Sage
112K - Dealer Maintained
My beloved 2003 QX4 has a slight thud when shifting from 1st to 2nd. It's had it since I bought it several years ago with 66k miles. It doesn't do it always, but seems to do it more in cold weather. It doesn't flare or slip, just kinda jerks a little. I don't think it's getting worse, but I'm noticing more being that it's December. I did have the dealer drain/fill the ATF at 90k miles but it still does this. Passengers don't notice, but I do and it bugs me. All other gears shift flawlessly and smoothly.
Does anyone know what would cause this? Maybe a solenoid?
I'm having the oil changed this week at the dealer and am considering mentioning it, but I don't want to end up with a massive repair bill.
Thanks for the help!
-Chad
Almost wondering if it might be something after the trans... Driveshaft u-joint, or maybe a diff mount?
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
I hear/feel a thud once in a while but it's not very frequent. I haven't looked into it.
Changing the fluid is a good idea regardless.
I second the suggestion to inspect U-joint(s); the driveshaft carrier bushing should also be inspected. Also grease the rear driveshaft if it hasn't been done yet - it should be done every oil change.
Randy K
Car: 2002 QX4
My 2002 does it also and has for as long as I've owned the truck. It's not so much of a thud in mine as much as it feels like I have a shift kit in it. Just a hard shift. I've taken it to 2 different transmission shops and both told me it was a known issue with the computer that controls the trans. Bear in mind both were wanting me to spend money with them, so that could have been complete bs.
jamescflowe
White/ Silver Sage
Yea, it's a hard shift - that may be a better way to describe it.
Towncivilian
If it's a hard shift, it's nothing to worry about. The hard shift between 1 and 2 and sometimes a slow/lazy shift between 2 and 3 is characteristic of our RE4R01A transmission. Your 2003 should not have any shift flare, that was corrected with the 2002 model year IIRC.
