maybe a shift kit will help? I am searching for transmission upgrade since I turbocharged my pathfinder and it slips at redline. Check this out.humsafar77 wrote:well the flare thing is still there and now another issue. whenever i switch the transmission back to 2wd from Auto or 4wd, i feel a big jerk in transmission and some time the switch simpli needs few tries to switch it back tom2wd
any ideas, is my transmission on verge of dying ?
p.s I do use 4x4 a lot since i drive the vehicle in desert
Yes, It wasyeldogt wrote:Was the transmission working correctly prior to the fluid change?? I don't think it is a water issue from washing the car.
The radiator was removed because it was damaged in a front end collision, basically a front TOP collision as I was on one side of the Dune in Desert and then a Range Rover came Flying from the other Side of Dune and Landed on my Bonnet (Hood) thinking of it a Landing Strip heheheheyeldogt wrote:Did they change the fluid in the auto transfer case? How many miles on the truck? Why did they remove the hose to the radiator?
have been Driving it like this for 2 months now, and you seem right, since earlier this Jerk (while Shifting Back to 2wd) was not there and this had developed just a week back, other than these two issue I don't feel any lacking in transmission performanceyeldogt wrote:Whenever you have a transmission issue it needs to be looked at ASAP -- as any slipping is very damaging to the clutch pack.
I bought this vehicle 3 months back and the earlier user Just changed the Oil and Oil Filter then, still I can see that the Oil colour s absolutely good and no burning smellyeldogt wrote:When I service mine -- I just do a simple fluid change from the pan drain and change out the transfer case and differentials -- I don't open up the transmission ... on any of my cars that have a drain. I also use the factory fluid Matic D -- requires 6 quarts for the trans and transfer case.
I have driven my earlier Pathy (basic model) Auto Transmission with Stick (not the Knob) for 4x4 engaging / disengaging, for three years and there was no jerk at all.yeldogt wrote: I have driven a few Pathfinders that had a harsh disengagement from 4x4 - but it should not stick.
Depending on your R50's year, those issues might have a fix; see this TSB.GregQX wrote:I recently had issues when mine sat overnight. in the morning the trans would either slip, rev real high, or completely miss 2nd gear and shift directly to 3rd. I also had a failing torque converter which was staying locked up and causing it to stall. All of my problems cleared up once the truck was fully warmed up.
Don't have an answer for his problem, but have to comment on the whole fluid change thing.GregQX wrote:
There's a lot of thoughts on the fluid topic. Over time, clutches wear. If the fluid hasn't been changed in a long time, the clutch material now becomes part of the fluid, and keeps the clutches somewhat together. Fresh fluid now doesn't have the "grip" that the dirty fluid does and just helps the process along.
Were you using OEM fluid? Did you do a fluid change/flush because there were symptoms of failure, or just out of preventative maintenance? I think that if the trans exhibits signs of failure and one opts for a fluid change (not having any service done previously to the trans), that's essentially playing Russian roulette as to whether it'll die soon or not.Buzzman wrote:Don't have an answer for his problem, but have to comment on the whole fluid change thing.GregQX wrote:
Every vehicle I've ever owned where I did a trans fluid change/flush, the transmission failed within 6 months.
Every vehicle I've driven where I left it alone has never failed.
Not sure what that means, but I don't think I'll be replacing my transmission fluid on my ('02) Pathfinder (with 250,000 Kms.) anytime soon.
It still shifts perfectly, and the transfer case/4WD system still functions like new.
Cheers.
