QX4 Transmission Problem
fdbandit
Car: 1998 Infinity QX4
Hi all. I just joined the forum. I purchased a 1998 QX4 2 days ago and I'm having a problem. The truck runs great and smooth in 2 wheel drive but when I select auto over 30 mph it shakes and shimmies and gets worse as the speed increases. Any suggestions (besides leaving it in 2 wheel drive) would be greatly appreciated.
fueler
Car: 2 Nissan's
2 BMW's
What kind of terrain you driving AUTO on? i hope it's not dry asphalt. Broken CV boots under the front??
fdbandit
From reading the owner's manual, the car should be set to auto regardless of road Conditions (within reason). CV boots appear to be fine. My best guess is a problem with the transfer case or the computer that controls the variable ratio when set to auto. I'm hoping the problem can easily he solved-like low fluid or something. The truck seems to "buck" like all 4 wheels are out of sync. Any direction to look will help.
nissandoms47
Car: 2002 Nissan Pathfinder SEV6-Custom 7" lift-33-1250R15 BFG KM2- a bunch of other s*** i cant think of
just keep it in 2wd unless you need the auto option. seriously, if you need 4x4 to stay in control on the street, you need better tires. the only time i ever use 4x4 is if im driving through a good 6-8 inches of snow in the road or on the trail.
KoukiS14
Car: 2005 Infiniti G35x
Lakeshore Slate / Stone
Mine runs in auto on dry pavement with no shakes or shimmies. It only sends power if the wheels slip. Do you also experience this in "lock"?
Auto can be used for driving on paved or slippery roads
fdbandit
It's actually worse in the lock position. I don't have a problem using the 2 wheel drive but the book does say to keep it selected to auto. I was just wondering if this is normal or if I have a problem.
nissandoms47
humm its hard to say without being there. but maybe your CVs are messed up, but i kindof rule that out because the r50 has drive flanges. so they CVs are always locked in. at what speed does this happen?
SnowSurfLax
Car: 1999.5 Infiniti QX4
2006 Infiniti M35 Sport
When's the last time you got a front end alignment? Just a thought
