Chuck Tribolet »
https://forums.nicoclub.com/chuck-tribolet-u120862.html
Fri Feb 18, 2011 9:54 pm
"camper" usually means something that goes on the back of a pickup.
The AAA tour books are a great resource for finding motels that will take dogs (I used to travel with two Newfoundlands and my GF).
I've got probably 70K miles towing my 2000 pound boat trailer with my '01. It's a stick shift, so less transmission issues. But the
tow capacity is rated at 3500 pounds (transmission-limited, autos were 5K).
Much over 2000 pounds and you'll want brakes on the trailer. Calif requires brakes over (IIRC) 2650 pounds, but over only 1500 pounds
if a house trailer or camp trailer. Never could figure out that disparity.
Shocks don't affect ride height, unless they are gas pressure like Bilsteins, and then they increase it VERY sightly.
Check your rear trailing arm bushings and the rear bump stops (inside the spring).
I'm sure there are aftermarket trans oil coolers which would be a good idea with an automatic.
