QX4 to Pathfinder bumper swap
PyRoMnAc
I like the look of the Qx4 bumper and was thinking of swapping one to my 03 Pathfinder...Has anyone done this before? Is it a direct swap?
fueler
Car: 2 Nissan's
2 BMW's
it would not fit the grille perfectly and it would not line up with the fenders clean (since the qx4 has exaggerated fender flares that blend with the bumper) but it would probably bolt on fairly easily.
slickroger
Car: 2001 Nissan Pathfinder
The fender flares will be an issue as Fueler said but they are essentially the exact same part.
I have a QX4 fender on my driver side the only difference is that the QX4 fender has 2 extra holes for the bigger flare. So essentially you could buy the bumper and have it fit but it might stick out a bit, you can only change the bumper though the grille peice wont fit because the headlight are a little different in size so the piece that goes under your headlight might have to be changed for a QX4 part
PyRoMnAc
Hmm sounds like more work than I wanna deal with...thanks for the heads up guys
