QX4 sways.. What could it be? I have been told two different repairs.
landofpar
Car: QX4
I have a sway to my car around corners.. I have been to two shops.. One shop tells me to replace the front sway bars.. and shocks.. The other shop, says no, there is no front sway bar to replace, but a rear Radail Arm, that needs replacing.. Which one of either of these repairs sounds right.. Or is it something else?
thank you keene
Bwana
Car: Denali
I'm going to move this so you'll get more help.
Welcome to NICO!
W O T
Car: 2001 Infiniti Qx4
What car? Describe the swaying....?
Blown shocks can give you a weird unresponsive feeling around turns...
But I dunno what exactly ur problem is
screwinitupagain
Car: 1997 Nissan Pathfinder SE
It's probably shot-to-hell rear bushings. It happens & is pretty common. It's called the "death sway" check this it: http://npora.ipbhost.com//index.php?showtopic=7052 as well as http://www.4x4parts.com/ubbthr...6933
This ismore than likely what it is & is a pretty easy fix. You can either buy new lower control arms & install them or you can buy just the bushings (poly are the best) & have them pressed in.
screwinitupagain
BTW you do have front & rear sway bars, but I have both of mine off & theres not much difference in ride (I did it for better flex during offroading).
