atraudes »
https://forums.nicoclub.com/atraudes-u214401.html
Wed Feb 17, 2016 3:29 pm
The only reasons I don't think the IACV is at fault is that it's not throwing a code and it doesn't die consistently. All of the experiences I've read from others on the matter is they always get a code thrown and they can't get it to idle at all. However, yours could be dying in a different way or maybe you've caught the early death rattles.
That being said, if you're up for buying a new one, I say go for it. The symptoms do suggest it as a suspect, and it's a part that is well known to fail on these vehicles, causing expensive repairs. I replaced mine as a preventative measure, so I think it'd be prudent either way.
Yep, as best as I could tell, the Hitachi is the OEM part anyway. I'm still having zero problems with mine.
As for the idle relearn, I doubt it'll make a difference at the moment since you aren't having a consistent idle issue. You will want to perform it when you get the new valve installed. It only takes a few minutes and is really straightforward. The steps are in the FSM and around here somewhere.
