ARKQX33V6 wrote:In 2 WD hard accel---spark plugs, advance mechanism is sticking or sluggish. Or transmission 1st is by-passing into 2nd or even 3rd
First of all... What?
And secondly,
Densetsu wrote:Have you done a coolant flush lately?
Over the recommended lifetime of coolant, the rust inhibitors reach lower and lower levels. If you've put off changing your coolant for too long, the radiator could start to rust. A coolant flush could loosen up a bunch of rusty threads from five years ago and cause everybody to shake their head under hard acceleration.
If this was intended for the OP, this thread is being brought back from the dead, he/she is probably long past this issue by now (at least I would hope so). If this was intended for ARKQX33V6, then kudos to you for being able to comprehend that...
