NickD85 wrote:I recently pulled the boards off, cut out the old tubing, and welded in a new length of steel tube stock where the rusted one was, and new steel brackets to attach them to the boards. It definitely wasn't a quick fix. Those longitudinal support tubes are definitely a weak spot on all the Qs, and seem destined to rust out. I could literally poke my finger through those supports before I replaced them
BUMP....nickD85, can you go more into detail and maybe give me some pics...a friend of mine is going to refabricate them for me over the winter but he said to look for replacement brackets...what/where did you use? I found some steel tubing for this job just need help finding brackets.
Mine is completely gone on drivers side, a good foot of tubing is non existant and just touching it it flakes off so this winter i will take them off, get them refabbed, primer and paint the underside and undercoat it and throw it all back on in the spring
ALSO last year someone welded everything and posted picture, i totally cant find that thread, if someone does find it post it here and deeeefinately in the how to section of the forum!!!
Modified by Qxxx4 at 6:05 PM 9/14/2009
