What I've done so far:
Replaced Upper and Lower rear control arms with the Dorman brands - 2 times. (RockAuto and Advance)
Jan/2012 and 09/2013 - $400.00 plus each time. (dealer told me a month ago that they no longer sell oem arms for them..)
The rear lateral arm bushings ( Just this afternoon) 60.00 w/bushing installation - They are true Nissan Oem bushings.
New Monroe Shocks.
Rear sway bar mounts and links - moog parts.
Front sway bar mounts and links - moog parts.
The front differential has issues as well as the cv-axles.., But I dont think that would make the rear-end sway side to side would it ? (removed front driveshaft due to transfer case bearing is bad and now am going to have to remove/replace cv-axles in front due to the bearings in them are coming apart.)
This vehicle is a daily driver and My main/only way to get to work.
AS for me.., I do mechanic work for a living and I am very web savy on finding info. But after talking to 4 different Nissan techs and 2 different Infiniti Techs.., I am still at a loss on why this truck sways left to right when hitting a dip in the road or during accelrating and hitting a dip at the same time. It goes to wobbling so bad at times.., (especially at 55MPH and up) that I swear it is gonna flip over.
The only thing I can think of is that I did not, both times, set this truck down on the ground to tighten the bolts up. (which I know may cause premature wear of the bushings) BUT I did use screw jacks to push the rearend up as much as I could whilst it was on the lift to get it almost to ride height.
I tested it this afternoon after reinstalling the lateral bar back on the truck. On the way home.., its still swaying side to side. So far I got over 1000.00 in parts invested into this issue/problem and still I haven't been able to figure it out.
PLEASE HELP!!! it's gonna drive me insane If I dont get this figured out...
Thanks,
Allen
