Hi
I been reading all the great tips and will have my Q serviced for this problem, I will have a good mechanic I know do the work and wanted to know how much time I should plan for the job to be done.. Is there any hoses that should be replaced under the plenum? My Q only has 28,000 miles but I am sure the hoses under the plenum will be brittle and probably need replacement. Any other service I should do while this is being done? Last thing do you use blue locktite or red?
Thanks for your help
