qx4/pathy vg33 A/C compressor interchangeable?
chicano2005
Car: 99.5 pathfinder
Well, seems obvious since being vg33 but i need reassurance.
I just recharged refrigerant but the compressor starts and quickly stops. Relay i believe its ok.
Any help suggestions or comments are welcomed!
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Yes, they should be interchangeable.
DAiNiUS
Car: 1999.5 Infiniti QX4
They are, but the connectors are a bit different. You might need to cut the connector from your current compressor and switch it out with the pathfinder one.
chicano2005
Thank you friends!
One last question, 96-00 pathfinder compressor should the same right?
Towncivilian
Yes, 1996-2000 compressors are all interchangeable.
