Learned something new today. I didn't think there were any grease points. Thx.Pwnin O’Brien wrote:If your QX4 is 4wd, then the only grease fitting on the vehicle is on the front driveshaft (for the front diff).
Nah, I don't have a pic. The problem is you have to position the driveshaft perfectly to access the zerk fitting. You have to move the car forward or backward a little bit until you get the zerk fitting facing downward. Also, the zerk fitting is a little hard to get to since the transmission cross member is right over where the zerk fitting is on the driveshaft. You definitely need a grease gun with a flexible hose.GRNMACHINE wrote:Always forget about the front driveshaft or propeller shaft as I think Nissan calls it... Still never greased, and not even sure what to grease on it.
Pwnin-do u have a pic of the grease point? I think I looked for it over the summer when I was doing xfer fluid change and didnt see it.
