sowlerthjh »
https://forums.nicoclub.com/sowlerthjh-u187247.html
Mon Jul 09, 2012 8:13 am
My QX4 has started to take between 5 and 10 minutes for the AC to kick in. When it does it is sudden, as if the compressor has suddendly turned on.
I have notice two ways that usually make it work (listed below), but I feel this is wrong as the car used to blow cold air straight away.
1. If I turn the climate control to "off", and then back to "auto" this usually makes the air cold.
2. If I rev the engine to around 5,000 rpm, cold air soon follows.
Once it has gone cold it stays perfectly cold for the rest of the journey, although not so much when stationary.
My mechanic has recommended that this is the condenser. Is this likely to be correct? I don't want to change it unnecessarily....
